מסך מחשב SAMSUNG Odyssey G50D QHD 180Hz רק ב₪1210!
₪1210 ₪1599
  • פאנל QHD IPS
  • קצב רענון 180Hz
  • זמן תגובה 1ms
  • DisplayHDR 400
  • VESA
  • AMD Radeon FreeSync
  • Eye Saver Mode
  • מעמד מתכוונן
מחיר מבצע: $280.44
סמנו V על קופון $10.45 מתחת למחיר
מחיר סופי כולל מיסים ומשלוח: $329.63 / כ₪1210
<span class="aawp-product__ribbon aawp-product__ribbon--sale">Sale</span>
       href="https://www.amazon.com/dp/B0CZPLQZ8P?tag=zuzu0c4-20&linkCode=ogi&th=1&psc=1" title="SAMSUNG 32-Inch Odyssey G50D Series QHD Fast IPS Gaming Monitor, 1ms, VESA DisplayHDR 400, 180Hz, AMD FreeSync, Adjustable Stand, Eye Saver Mode, LS32DG502ENXZA, 2024" rel="nofollow noopener sponsored" target="_blank">
    <a class="aawp-product__title" href="https://www.amazon.com/dp/B0CZPLQZ8P?tag=zuzu0c4-20&linkCode=ogi&th=1&psc=1" title="SAMSUNG 32-Inch Odyssey G50D Series QHD Fast IPS Gaming Monitor, 1ms, VESA DisplayHDR 400, 180Hz, AMD FreeSync, Adjustable Stand, Eye Saver Mode, LS32DG502ENXZA, 2024" rel="nofollow noopener sponsored" target="_blank">
        SAMSUNG 32-Inch Odyssey G50D Series QHD Fast IPS Gaming Monitor, 1ms, VESA DisplayHDR 400, 180Hz, AMD FreeSync, Adjustable Stand, Eye Saver Mode, LS32DG502ENXZA, 2024        </a>
        <ul><li>BOOST YOUR REALITY: QHD resolution packs 1.7x the pixel density of Full HD and boasts detailed, pin-sharp images; Fast IPS panel delivers clear colors and wide 178° viewing angle for clarity from any viewpoint</li><li>REACT IN REAL TIME: Speed through scenes; 180Hz refresh rate eliminates lag for exhilarating gameplay with ultrasmooth action; A 1ms¹ response time (GtG) enables frames with minimal blur, allowing you to jump on enemies the second you see them</li><li>SHED NEW LIGHT ON HIDDEN DETAILS: VESA DisplayHDR 400 delivers more contrast, with deeper blacks and brighter whites, to help you uncover hidden enemies lurking in the shadows; Even in dark scenes, every detail shines with clarity</li><li>STAY IN SYNC w/ THE ACTION: AMD Radeon FreeSync keeps your monitor and graphics card refresh rate in sync to reduce image tearing; Watch movies and play games without interruptions; Even fast scenes look seamless and smooth</li><li>MOVE INTO YOUR COMFORT ZONE: Reach new heights winning with a monitor that swivels, tilts, and adjusts until all your enemies are in perfect view; Achieve total gaming comfort with a display that can be freely moved to accommodate the way you play</li></ul>        </div>
            <a class="aawp-button aawp-button--buy aawp-button aawp-button--yellow aawp-button--icon aawp-button--icon-black" href="https://www.amazon.com/dp/B0CZPLQZ8P?tag=zuzu0c4-20&#038;linkCode=ogi&#038;th=1&#038;psc=1" title="לקנייה באמזון" target="_blank" rel="nofollow noopener sponsored">לקנייה באמזון</a>
Last update on 2024-08-18 / Affiliate links / Images from Amazon Product Advertising API
