כרטיס מסך חזק בצלילת מחיר!
מחיר מבצע: $372.96
מחיר סופי כולל מיסים ומשלוח: $454.26 / כ₪1,710
בארץ החל מכ₪2419
<span class="aawp-product__ribbon aawp-product__ribbon--sale">Sale</span>
href="https://www.amazon.com/dp/B0CBK7BRL9?tag=zuzu0c4-20&linkCode=ogi&th=1&psc=1" title="MSI GeForce RTX 4060 Ti VENTUS 2X BLACK 16G OC Graphics Card - RTX 4060 Ti GPU, 16GB GDDR6 (18Gbps/128-bit), PCIe 4.0-2 x TORX Fan 4.0 - HDMI 2.1a, DisplayPort 1.4a" rel="nofollow noopener sponsored" target="_blank">
<a class="aawp-product__title" href="https://www.amazon.com/dp/B0CBK7BRL9?tag=zuzu0c4-20&linkCode=ogi&th=1&psc=1" title="MSI GeForce RTX 4060 Ti VENTUS 2X BLACK 16G OC Graphics Card - RTX 4060 Ti GPU, 16GB GDDR6 (18Gbps/128-bit), PCIe 4.0-2 x TORX Fan 4.0 - HDMI 2.1a, DisplayPort 1.4a" rel="nofollow noopener sponsored" target="_blank">
MSI GeForce RTX 4060 Ti VENTUS 2X BLACK 16G OC Graphics Card - RTX 4060 Ti GPU, 16GB GDDR6 (18Gbps/128-bit), PCIe 4.0-2 x TORX Fan 4.0 - HDMI 2.1a, DisplayPort 1.4a </a>
<ul><li>NVIDIA GEFORCE RTX 4060 TI GPU - The 4060 Ti features advanced Ada Lovelace architecture for superior 3rd gen RTX ray-tracing capabilities (1080p) & comes with 16GB of GDDR6 memory (18 Gbps); DLSS 3.0 enhanced frame rate performance supported</li><li>MSI VENTUS EDGE - The RTX 4060 Ti VENTUS 2X BLACK 16G OC is a factory-overclocked GPU variant of the RTX 4060 Ti VENTUS 2X BLACK 16G; This is an enhanced option for gamers & creators looking for a graphics card with an optimal value-to-performance ratio</li><li>DUAL TORX FAN 4.0 COOLING - TORX Fan 4.0 technology features paired blades, ZERO FROZR (0 RPM mode); and heat pipes running through the heatsink</li><li>SPARTAN DESIGN - A sturdy backplate with flow-through design reinforce the chassis, while internally an enhanced PCB includes premium electrical safeguards</li><li>FUNDAMENTAL & EFFICIENT - The 2 slot card (PCIe 4.0 x16) is 199 mm long, weighs 595 grams & has a recommended PSU wattage of 550 or higher (8-pin, 165W power consumption); Rear ports include 3 x DisplayPort 1.4a & 1 x HDMI 2.1 (4K/120Hz)</li></ul> </div>
<a class="aawp-button aawp-button--buy aawp-button aawp-button--yellow aawp-button--icon aawp-button--icon-black" href="https://www.amazon.com/dp/B0CBK7BRL9?tag=zuzu0c4-20&linkCode=ogi&th=1&psc=1" title="לקנייה באמזון" target="_blank" rel="nofollow noopener sponsored">לקנייה באמזון</a>
Last update on 2024-06-30 / Affiliate links / Images from Amazon Product Advertising API
