מערכת אנדרואיד זולה להפליא! כולל בלוטות', GPS וWIFI!
עם אנדרואיד 8.0
Description:
USB interface has 2-way tail line output
1. Upgraded Dual system mirror link:IOS/Android mirror link
IOS one-way :IOS supports mobile phone one-way projection to the machine
Android two-way:Android supports mobile phone two-way connection
2. Built-in GPS receive: Users can purchase directly from play store for offline navigation. With wifi connected, Google Maps can be used perfectly, you can go
anywhere you want and never get lost again!
3. Built-in WIFI: Connect to WIFI, and you will find a new world, the most convenient one is the online map.
4. Rear view camera: Need to choose the camera,the car is connected to the reverse gear to automatically switch(requires optional)
5. Steering wheel control: Through it you can control the functions you need by steering wheel, more convenient
6. Built-in bluetooth 4.0 with A2DP/Hands Free/Phone book
Support bluetooth hands-free calls
bluetooth music player
Auto loading phonebooks
7. High definition 1080P: Full capacitance touch screen for easy operation, well designed user interface for car only
8. Driving recorder: You can choose a recorder, and the car has playback, the evidence can be retained
9. Double USB adapter input
10. Built-in FM with 30 preset stations
FM Radio: Online music you can transfer the music to the car stereo by FM to enjoy the original car stereo sound
11. Support file manager: Support download, install and delete over thousands of android apps
12. Support multilanguage: Support languages, up to 70 national languages
13. You can enjoy music from you mobilephone without any cables, and also support USB connetion.
- מומלץ לשלם בדולר.
- מומלץ לשלם בפייפאל (ראו מדריך מלא). אין צורך בביטוח משלוח בתשלום בפייפאל.
- קונים מעל לרף המס (75$)? אתר זה כולל אפשרות ביטוח מכס! להפעלה סמנו בקופה V על "Tariff Insurance". במידה ותחוייבו במיסים – הגישו את הקבלה לשירות הלקוחות באתר לקבלת החזר.
